Unigine Valley 1.0 Benchmark
Publisher: Unigine
Unigine's free Valley 1.0 benchmarking tool works well as a graphics benchmark as it is GPU limited and is thus incredibly taxing on the GPU whilst placing the CPU under very little stress. Unigine's scoring system is effectively linear: a card with 2,000 points is considered twice as fast as one with 1,000 points, and half as fast as one with 4,000 points.
        Overclockers UK Infin8 Nebula
        Utopia Pandora
        MSI GTX 970 Gaming 4G
        Cyberpower Infinity X55 Pro GT
        AMD Radeon R9 290 4GB
        PC Specialist Apollo 703
        AMD Radeon R9 280 3GB
        AMD Radeon R9 270X 2GB
          2000
          3000
          4000
          5000
          6000
          7000
    Score (higher is beter)
PCMark 8 Video Editing
Video Editing V2 Part 2 (Creative 3.0 test suite)
This workload uses
FFmpeg to apply video enhancement filters to a high bitrate H.264 video and then encode it to a format suitable for distribution. The FFmpeg binary used is custom built by Futuremark using a development version of the source available from the project's code repository. The test applies a deshaking filter to a source video at 3,840 x 2160 (4K UHD) before scaling down and outputting at 1,920 x 1,080 (1080p).
        Utopia Pandora
        Intel Core i7-4790K (4GHz/4.8GHz)
        Intel Core i7-5930K (3.5GHz/4.55GHz)
        AMD FX-8350 (4GHz/4.6GHz)
          200
          300
          400
          500
          600
    Seconds, lower is better
PCMark 8 Photo Editing V2
This workload involves making a series of adjustments to a set of photographs using
ImageMagik - an open-source image processing library to adjust brightness, contrast, saturation and gamma. When a favourable balance is found, the changes are then applied to the rest of the images in the set. TIFF files up to 67MB in size are used.
        Utopia Pandora
